Weigh the piston assembly if you"re worried. The 4 ring design is "early" design, the 3 ring is "late" design. Later rings will be slightly different than early but 3 ring is more current. piston skirt length should be close to same, wrist pin to top of piston should be same, oil control ring may be wider, multipiece insted of plain or narow space multipiece. Ford tractors have same situation, balance problems with mixed 3/4 ring pistons is not noticable. 3 ring piston might have a little more blowby on worn cylinder but pressure of 120 or so is not going to be much. Diesel pistons are more of a concern- the 4 rings are needed for 250+ pound cylinders. RN
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
