Janicholson said: (quoted from post at 21:47:32 01/18/09) Whew, That mag is decidedly bizarre inside. My thoughts were just to get an operational spark, but I guess not on that unit. As to the polarity of spark. I agree the only small advantage to a center to ground spark is the thermionic effect of a hotter point of origin.
The plasma between the electrodes just needs to start a good fire.
Several years ago an extreme test was made with consumable electrode high current Capacitive discharge. (I have no idea where it was published) This experiment used currents of 20 to 100 times those found in normal spark ignitions.
It actually produced a flash of superheated gas into the chamber (test cylinder) that produced a significant improvement in combustion rate and flame travel due to a larger flash origin for ignition. The peak mean effective pressure was greater, and power was incrementally increased.
It was determined that the cost of consumable electrodes, and the complexity coupled with metal being "eroded" off of the tips, was not a viable solution. CDI and other hot spark electronic igniters and coils pumping into wider spark gaps (some at .080") are a reflection of the value of the idea. Exotic metals and heat control are also in the same realm of applied science. Fun discussion. His rebuilt mag looks great. I hope it performs. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
