Re: pto adjustment on 300u Here is my take. Look at the linkage and be certain it has no lost motion, there are pins and woodruff keys in the system that can be loose. Fix if found. Place the lever 1/2 the way between the latching points of on (up) and off (down). Remove the little dome cover on the PTO box. Under this will be two lock nuts and two adjusting screws. The PTO should turn by hand (engine off). Loosen the lock nut, and turn the front screw in until you can feel the shaft start to resist turning by hand. Loosen it just until it will turn free, no more. Do the same for the rear adjuster so that it can rotate free, but no more. The front adjustment is the drive adjust, the rear is the brake adjust. If the screws are down level with the adjustment lock nut top, the bands are worn, and will need replacing, or relining at a clutch shop. That is not quite the book way, but I have used it many times. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
