Posted by the tractor vet on January 19, 2009 at 19:31:25 from (99.167.210.144):
In Reply to: Front axel on 806 posted by Larry B on January 19, 2009 at 17:20:49:
I have fixed several and it is not that big of a deal to do . Ya just cut out the old and have a new piece made up and when ya are cutting out the old one it is most critical that you do not over cut and inlarge the org. hole in the tube . once ya have the old bushing or tune cut out chamfer out around at about a 45 degree angle and weld in the new tube with good penetration weld , myself i run 7018 for rod . It is wise to order in a new axle pin so that the machine shop can fit it . The pin is where the grease fitting is so there is no need to try and install a fitting in the bushing. a bushing with about a 1/4 inch wall will be enough .
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
