Posted by Janicholson on January 20, 2009 at 17:02:25 from (64.83.227.252):
In Reply to: engine miss posted by Stan Bainter on January 20, 2009 at 12:34:02:
Put a can under the carb and drain fuel from the float bowl into the can. THere should be a steady and strong stream the size of a 16d nail or better for at least 3 or four minutes. If it does flow well then fuel supply is OK. A manifold that is cracked can do that trick. As it heats, the manifold expands and causes an increasing air leak that leans out one or more cylinders. To check use a propane torch (Little bottles), unscrew the nozzle to allow propane (not a mix of air and propane) to come out of the small tube. Start the tractor, and with a modest flow of propane, see if mooving the source around on the manifold area makes it run better. If it it leaking at a gasket, or external crack, it will pick up speed. Allowing propane into the intake at the carb will also richen it and if lean make it run better. If the intake is cracked, or has a hole into the exhaust manifold, it will not show up with the propane trick. Be aware of fire hazzard, and outside is best to do this experiment. JimN
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
