Posted by Janicholson on January 24, 2009 at 16:15:37 from (68.112.156.69):
In Reply to: Re: C Farmall smoke posted by thumbanger on January 24, 2009 at 15:35:36:
there are two options higher priced teflon Perfect circle style seals and umbrella seals. They should have books with tractor data (ask to speak to the older guy!)with stem and guide specs in them. Simply stated the valve train is removed from the top (keep the push rods in order, and do not pull them out of the block fast, the lifters can be tugged out of their bores if pulled up fast) then put a 16inch piece of cotton rope in the cylinder through the spark plug hole (leave some sticking out), and turn the engine by hand to compress the rope against the valve heads. this prevents them from dropping into the cylinder when removing the retainers and installing the valve seals. JimN
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
