Posted by tractorsam on January 24, 2009 at 17:12:01 from (142.177.27.222):
In Reply to: SMD-WD9 posted by henryv11 on January 24, 2009 at 17:01:59:
On the letter series diesels there were two levers used in the changeover. I believe the number series only used one lever.
On a SMD one lever controls the injection pump (as you don't want diesel being injected when it's running on gas) and also acts like a throttle on diesel. The other lever opens the starting valves (a third valve in each cylinder) and operates a butterfly in the inlet manifold to direct air around or through the carburetor as required. The shaft that the butterfly is on also has an electrical switch attached to engage/disengage the mag/distributor. The starting valve opens to an additional combustion chamber to lower the compression ratio sufficiently for it to run on gasoline. Hope this helps, Sam
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
