The mounting flange (where you loosen the clamps to set timing) has a code letter stamped into the outer edge. The unit from the C may have originally been on something else. The C distributor is code J, the M distributor is code A.
Code A maximum advance is 40 degrees at 1400 rpm.
Code J maximum advance is 30 degrees at 1400 rpm.
By the way, the Super M used distributor J, so I'm guessing it doesn't matter much which one you use.
By the way, the springs determine how quckly the spark advances but the maximum is determined by the shaft. Both the springs and shaft are different between the A and J distributors.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
