Posted by Doug Hansel on January 30, 2009 at 16:51:17 from (75.103.133.201):
Hi, I have an International 424 gas tractor. Over the last few months it has developed an issue with the carburetor. It leaks fuel and eventually drains the gas tank. I assume bad float or needle valve. The tractor ran fine so I procrastinated and just turned the fuel on and off when I used the tractor. Now the tractor is cutting out and popping whenever I load it. I noticed some moisture around the oil filter can and then opened up the oil filler cap to discover an unusual amount of crank-case pressure and oil spraying out of the hole. Is it possible for the carburetor to have overflowed so much gas that it got in the crank-case? I thought maybe the crankshaft could be churning the oil if it were too high? But why the popping and cracking? Any ideas would be appreciated
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
