Thanks to all for your help. (El Toro, thanks for pulling the photos up.)
I believe you found myanswer. I first checked the oil and it was at the "full" line.
As it appeared to be a gasket, I started looking again. The only one I had not replaced was the retaining bolt gasket, which happens to be brass and therefore never occurred to me. I picked up a new one this morning. Pulled off the cover and filter and removed the case gasket I just put in a month ago. I cleaned out the groove to be sure nothing was in there. I did have a new one so it went in.
Put everything back together with the new retaining bolt gasket and fired it up. (To answer JimN, I have 10-40 in it right now.) Right at the start the gauge read 40#, I let her run 15 minutes or so and pressure lowered to 30#. Started pushing back snow banks for another hour and the gauge was reading 20#. It never dropped lower than that.
My guess is that, with your help, I may have this problem resolved. Thanks.
I"ll have to let you know later on the electrical problem. I tried the meter I have across the battery terminals and could not get a good read. It never settled down. When I get a good check in the next day or so, I"ll re-post.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
