Ok, so here's what I found: The voltmeter has two 'lugs' or threaded rods for the wires to attach to. These lugs are theoretically insulated from the metal housing and mounts. One of the lugs had corroded and worked itself loose inside the meter housing, which is connected to (grounded to) the metal frame. When I jiggled the wires, it was bumping the metal and grounding itself and causing the heat (Smoke!) and/or sparking. The switch is fine. Blamed falsely. It was the meter.
So, we're back up and running, and I now need a new meter.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
