240 hydraulic problems
Posted by international embalmer on February 03, 2009 at 16:00:59 from (70.196.18.255):
I have a 240U that I recently repalced the hydraulic pump on. all is well right???? Well not really. the pump workes fine (better than ever) it picks up a load all the way and despite some adjustments and small parts missing that I repaced I got the unloading problems sorted out. Now I have a horrible problem with Foaming. It looks like air (no slimy water in oil look) I checked the screen, changed the oil and beceause Hy-Tran is not so easily found here I put in ISO 46 hydraulic and transmission oil to 1/2 inch below the filler. Foam and more foam. Comming out of the breather and every joint in the system until the level is 3/4 inch below the filler plug threads. Now the hitch wourks fine but still with the foam. Is it the oil or is something more happening? Any Help would be Great!!
Thank You
Jim
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
