He could try rotating the upper shaft manually with the engine off and the transmission in neutral. If the coupling is coming loose, there is probably going to be some free play. If the coupling is OK, it should be pretty solid.
If the trouble is there, I wouldn't expect the noise to be much louder with the cover off. So I guess it is on open question whether the louder he is hearing is enough louder to prove it is from inside the transmission.
So far, we haven't talked about whether there could be a noise source related to the PTO. I'm assuming this whole situation is going on with the PTO turned off, which eliminates most things PTO related.
I'm inclined to think a chip is imbedded in the oil slinger gear.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
