Posted by Bob M on February 05, 2009 at 18:20:35 from (74.74.133.120):
In Reply to: Super A - Generator posted by Brian Luton on February 05, 2009 at 17:57:27:
Brian - The Super A will start reliably in the coldest weather with a well-maintained 6 volt electrical system. So unless your tractor is a daily worker, I'd stay with the stock 6 volt system.
A good system will charge 12 - 15 amps (about 2/3 right deflection on the ammeter) after startup. It sounds like yours is charging very little if it all. But before you tear into the generator, make sure generator is indeed the problem and not the regulator or wiring.
A quick test: Run a temporary jumper wire between the generator "F" terminal and a GOOD ground. Now run the engine at governed RPM and note the ammeter reading.
If the ammeter shows 12 - 15 amps the generator is fine - the problem is a bad regulator, a bad regulator ground or a wiring problem. But if if the ammeter's still centered then be looking for a generator problem.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
