jonathan mirgon said: (quoted from post at 13:22:25 02/06/09) Do the c-123 replacement rod piston pin inserts have to be machined to obtain proper clearance or are they a press them in and go design ? Just wondering if the rod insert replacements will require machine shop work ?
Piston pin bushings are a press fit in the rod. After they are pressed in they should be burnished which involves pressing a special tool through the bushing to expand it to insure a tight fit in the rod. After burnishing they will be about .010 smaller than the pin. They need to be honed to .0002 clearance. When properly fit, with the pin and bushing lubed with 30 weight oil, when held with the pin vertical, it should slowly slide through the bushing with just its own weight.
The crankshaft bearings do not require any machining but the big end of the rod must not be distorted. they do need to be matched for proper size with the crankshaft.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
