Posted by JimB2 on February 07, 2009 at 17:57:02 from (208.124.162.51):
In Reply to: 464 diesel posted by carlsandberg on February 07, 2009 at 17:17:06:
Hi Carl, 464 should have D-179 3cyl German Diesel engine. There are no glow plugs but there is a START position on the STOP/START/RUN control lever that acts like a choke for a gasoline engine.
There is a bleeder screw on top of each rear axle, looks like a grease zerk. Require clean bucket and 1/4 or 5/16 inch clear tubing that will fit over bleed screw nipple. To bleed the brakes run the tractor until the Hytran hydraulic fluid reaches operating temperature. Run engine at fast idle 1400-1600 RPM, block rear wheels. 1)With tubing connected to nipple on bleed screw and other end in clean bucket, loosen bleed screw and let hydraulic fluid drain until air bubble free, then close bleed screw. Repeat on other brake. Do not pump brakes while bleeding.
Top up hydraulic fluid with fluid caught in bucket, make sure transmission fluid level is full or over full. Also check for leaks by bottom of dash and along top of transmission cover. Brake lines run from under battery box along top of transmission to rear axles. May have to repeat bleeding and if bleeding only lasts a few days then repost and I will give a procedure to diagnose if it is leaking seals in brake piston.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
