The front of the engine has a set of gears that drive(from the crankshaft to the cam shaft, then to the side where the hydraulic pump (If it has a live hydraulic system, meaning that it will raise the bucket with the clutch pushed in) and distributor are located The cam shaft is driven by a keyway that locates the lobes in relation to the pistons. If the system wears the gear and keyway, it can fail with backfiring as a result. Other causes can also happen in the distributor system. Do a compression check. Buy or borrow a compression tester (make sure it fits the larger size spark plugs. Open the throttle all the way open, spark plugs all out, Ignition off, and fuel turned off. Crank the engine for at least 5 fill compression cycles. and read the gauge. It should be more than 120PSI. do the remainder, and tell us what the reading is. We will go from there. JimN
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
