Posted by Red Mist on February 08, 2009 at 16:44:06 from (67.142.130.41):
In Reply to: flywheel starter ring posted by Buzzman72 on February 08, 2009 at 10:25:24:
Joe the tractor guy said: (quoted from post at 11:25:24 02/08/09) I have a super A. The flywheel starter ring has gotten worn to the point that It needed replaced. When inspecting the old ring on tear down I cant see any reason why it would ware so bad. The starter seems to be pushing the starter gear deep into the teeth, still in certain spots the ring gear teeth are wore to the point where it wouldnt bite. Is this normal to have to replace a gear over time? Should I be checking something else? My tractor has been converted to 12 volt. Do I have too much push on the starter bendix??
Thanks
Joe: All four answers provided you are exactly correct and if you follow them, you will be pleased with the results.
"mike, the still learning and don't know much tractor guy"
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
