Re: flywheel starter ring
Posted by ScottyHOMEy on February 08, 2009 at 19:17:24 from (71.241.192.17):
In Reply to: flywheel starter ring posted by Joe the tractor guy on February 08, 2009 at 10:25:24:
All good advice below.
An engine will come to rest when shut down when the last two unfueled cylinders find a balance between compresion and exhaust. On an inline four-cylinder that means that the next time it's started, the starter gear will bite within two fairly narrow ranges on the ring gear, and you will see the wear in two spots pretty much opposite each other.
Replace the ring gear and go with the new-style clutch-type starter, and the whole rigging will outlive you.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
