Turn the crank to #1 top dead center (align the timing mark on the pulley with the pointer on the cam gear cover). DO NOT turn the crank again once you've set it at TDC!!
Remove the distributor cap and mark the housing where the rotor is pointing. It could be under the #1 or #4 plug tower - it doesn't matter which. You're now OK to pull the hyd pump and distributor assembly.
To replace the pump, mount the distributor to the new pump. Then turn the pump drive gear until the rotor points at the mark you made on the housing.
Now temporarily fit the pump onto the engine and seat it fully. Note the rotor has turned a few degrees away from your mark as the helical pump gears meshes with the cam gear. Note which direction and how far the rotor turned.
Now pull the pump back out, turn the drive gear a few degrees as required to compensate for the rotation (ie. to "lead" the rotor) then fit the pump back on.
If you do it right the rotor will be at the mark on the dist housing when the pump seats. Bolt the pump down and you should be good to go!
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
