Re: farmall 300 hydraulics
Posted by pete 23 on February 10, 2009 at 10:25:18 from (173.87.1.12):
In Reply to: farmall 300 hydraulics posted by E. Hanson on February 09, 2009 at 17:10:46:
You are dealing with a spool valve and there is no positive seal as they need clearance to operate.There is no o-ring in the valve that hold the load. Wear over the years allows more leakage past the lands. Make sure though that it is not the cylinder leaking as a leaking cyl will cause pressue to equalize onto the rod side of cyl and about quadruple the pressure making it impossible for spool valve to hold up very long. You can add a single action check block or altelrnating check valve and this will positively hold the load up.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
