Re: Farmall 560 2 point won't raise
Posted by LIVIN LUCKY on February 15, 2009 at 09:00:26 from (76.234.131.40):
In Reply to: Farmall 560 2 point won't raise posted by josh740 on February 14, 2009 at 18:51:13:
josh have the same problem with mine found out the spider gears was stripped pull the cover of under the steering wheel the top vavle asemble with the two bolts take the cover off the gears r there if only couple teeth r missing u can turn that to make it work but be careful that is timed
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
