Spacer washers work well. Ten to twenty thousandths would be good. The bolster shaft on my '51 H has 15 thousandths of end play and works well. If you have access to a dial indicator on a magnetic base, you can measure the distance easily. With the sector gear tight on the tapered spline, measure the vertiacl distance the shaft travels until it runs up to the thrust bearing. Subtract 10 to 15 thousandths from this number and that is how thick to make your spacer. If the spacer is too thick, you lock up the shaft, too thin and the shaft hammers going over rough ground. Put your spacer between the thrust bearing and the contoured washer that mates with the shaft fillet.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
