Posted by Janicholson on February 17, 2009 at 06:42:18 from (199.17.6.128):
In Reply to: Re: Farmall A valves posted by ScottyHOMEy on February 17, 2009 at 06:14:35:
I didn't check the part numbers, I just have experience with the two heads, Dist/gasoline, they do not have interchangable valves. The difference between the two are obvious. If there is just a few thousandths difference it may be that the thickness of the new valve at its head/margin (rim between face and flat of head) is thicker, a good thing. The use of Dist valves will hyper extend the spring, and not work with the geometry of the rockers at all. Soooo I think you were correct and I was on the wrong topic. A gasoline head would still be desirable if there is a choice. Thanks JimN
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
