Posted by Jim Becker on February 17, 2009 at 08:19:50 from (71.252.139.51):
In Reply to: SUPER A AXLE SEALS??? posted by NC-SUPER-A on February 15, 2009 at 21:35:31:
HTH you were on a good track with the R91 theory. Unfortunately, IH considered lip seals to be assemblies. Under the R number system, they are pretty well all R9x.
Here is the process I went through:
I found the same 3 numbers in the Super A manual as the rest of you. Thought the 140 may have essentially the same seal with a newer part number, since the manual was newer. Found the number 273563R91.
Then went to Messick's and typed in 53599D. They said superceeded by 38220R91. Clicked on that number, and they listed all the above numbers as superceeded by it (at $12.xx).
On a hunch, I checked that number in the ATIS Cub FAQ. Found the same number listed for the same application on the Cub. Listed cross references:
Federal Mogul 472070
National 14702, 472070
CR 18104 (use 2)
National 470267SSR
CR 512309BT
These crosses are what various CUb owners have found that worked for them. I have found CR 512309BT in an IH reference. Check the dimensions, but that is probably what you need.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
