But the Hy-Tran doesn't leak past the inner seal. The inner seal is the kind with a thin rubber-coated spring wound around the axle and no fluid gets past it. The axle and housing between the inner seal and the outer bearing was dry. It's been dry for quite a while and I've been keeping the transmission full.
There is no bearing cap. On the axle from the outside in is the wheel hub, an oil seal and the bearing and that sits against the bearing cup. Then there is about 18 inches of axle until the inner seal.
The local dealer service manager insisted that the axle should be dry and there should be a grease fitting on the end of the carrier. There is no fitting and no obvious place to put one. Would the International Service Manual have instructions on keeping this bearing greased?
Today's Featured Article - The Rescue of a Fordson F - by Anthony West. Introduction I live in the UK and have for many years restored Fordson tractors (in the main model N's). I have also restored and shown model F's, E 27N's, Field Marshall Series 2, David Brown Cropmasters and the old rey Fergeson T 20. At one time I had seven restored examples which were shown and used in ploughing matches. As most restorers, I have a number of war stories I can relate on a range of topics that may help other like minded and interested people. Perhaps my first p
... [Read Article]
Latest Ad:
[More Ads]
