This is one of those type question youre apt to get varied opinions on, so I will JUMP RIGHT IN AND kick it off with an engineers perspective.
1) To get all the benefits that improved elec switch has to offer n get the most "bang for the buck" I recommend (versus the old stock coil) a matching high energy high voltage coil such as their flame thrower series BE SURE N LET PERTRONIX MATCH THE COIL FOR THE SWITCH as some coils may draw more current n require a higher current rated switch.
2) If you run the elec switch and a high energy high voltage coil, Id widen the stock plug gap to more like at least 0.035 to 0.045 or even a bit more. With the higher energy ignition and wider plug gap you end up with a wider hotter fatter spark which discharges more energy (volts x amps x time) across the plug gap then a stock ignition...THATS JUST PHYSICS
3) Since youre running at a higher firing voltage if you widen the plug gap, you need good quality plug wires and a good clean dirt n oil n moisture n crack free distributor cap. Go with what Pertronix recommends which may be 7 or 7.5 mm etc wires but too big of a wire (8mm) might not fit just right in a stock cap CHECK WITH PERTRONIX
DISCLAIMERS:::::
From an engineers standpoint I wouldnt expect much more if any net HP gain BUTTTTTTTT I would expect better starting and idle performance versus the stock ignition
DO NOT wire it at the wrong polarity you will let the smoke out grrrrrrrrrrrr
Use a good heavy duty battery and 00 gauge battery n starter n ground cables (regardless of any ignition on a 6 volt system) cuz if shes hard to crank n the battery voltage drops drastically the elec ignition may not perform correct
DRAWBACKS a) IF the old points burn you can file them n probably get back to the shop butttttttttt if the elec switch stops YOURE SCREWED b) The elec switch costs more
ADVANTAGES Better starts n idle,,,,,,no points or condensor problems,,,,,more spark gap energy (volts x amps x time) across a wider plug gap is available for that wider hotter fatter spark AGAIN those are the laws of physics IM NOT SAYING THATS NECESSARILY BETTER its just a fact
Your tractor youre choice, best wishes BE SURE N LET PERTRONIX MATCH THE COIL N SWITCH FOR YOUR GROUND AND CURRENT RATINGS ETC
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
