Posted by Harold H on February 22, 2009 at 05:29:01 from (98.18.181.226):
In Reply to: Fuel Types posted by IHStandardMan on February 22, 2009 at 04:37:17:
"All Fuel" was a John Deere term and was not used by IHC. Most IHC models were offered for; kerosene, distilate, or gasoline. In the South we called distilate "tractor fuel".The diesel tractors were of different design. Both the kerosene models and the distilate models had a lower compression ratio than the gasoline models (kerosene had lowest, then distilate, then gasoline, then high altitude gasoline had the highest compression ratio) and had a seperate small tank which was filled with gasoline for starting. They also had adjustable shutters on the radiator and a heated manifold as it was necessary for the kerosene and distilate engines to run hotter in order to efficiently burn the fuel. During the 30's, 40's, and early 50's distillate was the fuel of choice in the South. I think kerosene was mostly burned overseas at the time. In the 50's distillate was gradually phased out in the South and LPG became the fuel of choice untill diesel started gaining in the 1960's. I only know about the SE USA but I don't think distilate was ever used very much in other parts of the USA. A kerosene or distillate tractor will run fine on gasoline, just have a little less power. The John Deere term "All Fuel" ment it would run on kerosene, distilate, or gasoline and had a lower compression than the JD gasoline models and also had shutters and heated manifold.
The W-9 was offered in kerosene, distilate, or gasoline. The WD-9 was a different dual combustion chambered head engine which started on gasoline and ran on diesel.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
