Re: 300 u fast hitch
Posted by Dellbertt on February 25, 2009 at 17:14:55 from (209.172.22.242):
In Reply to: 300 u fast hitch posted by farmall dave on February 25, 2009 at 04:50:43:
Dave,
I had a sticky controller once on my Case and wiggling the lever and tapping LIGHTLY would free it up.
Use JimN thoughts and do some trouble shooting.
Does it happen cold as well has hot.
What fluid type and level.
Stock hyd pump?
Does rear lift work better in single or double action.
No leaks?
Tap LIGHTLY on controllers, safety and priority valves.
Did you check the hyd screen under the seat in the reservoir (this is a last ditch effort as pulling the reservoir top is a PAIN.)
Pump Noisy?
Does PS shake?
Dell
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
