Hi Rockin, you can check if it is the lift cylinder is leaking or the lift control valve. With an implement on the 3pt hitch close the valve at the front right side of the seat then turn the tractor off. If the 3pt hitch still goes down then the problem is most likely leaky lift cylinder "O" rings. Be sure to open the valve before starting the tractor again. If the 3pt stays up the problem is else where. If there is air in the system usually you hear the hydraulic pump whining and the hydraulic lines vibrating.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
