Posted by Gary Hutchinson on February 26, 2009 at 13:53:46 from (192.236.20.254):
In Reply to: Re: 756 alt posted by bc on February 26, 2009 at 11:50:16:
For my money, I'd go with an ammeter no matter what kind of alt/reg combo you are using. It gives you more information about what is going on in your system. All a voltmeter does is tell you that you are building enough voltage that you should be charging. The ammeter actually will tell you that plus whether there is more juice going into the battery (charging), or more coming out (discharging). If the meter shows the direction is charging, then you know your alt/reg output is enough to run your ignition, accessories, etc. and still have enough left over to charge the battery. Normal operation is that when you first start, you'll see 10-15 amps of current in the charge direction and then slowly fall off to just a couple of amps after you've run for awhile.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
