Below is my reply to Henry's post which is not accepting replies:
Henry - Since your loader has 2-way (push-pull) lift cylinders, you can get by with less reservoir capacity than if it had 1-way (push only) cylinders. However even with 2-way cylinders there will still be SOME net movement of oil out of the reservoir when the cylinders extend. The oil volume reduction will be equal to the displacement of the cylinder rods.
If your tractor’s existing reservoir capacity is inadequate for your loader it’s not difficult to add a 2nd, auxiliary reservoir then tee it into the pump suction line. It can be mounted most anywhere, but at or above the level of the pump is preferred. The reservoir connecting line should be the same size as the pump suction line. Also it must be well vented with the vent protected with a breather/filter to keep dust, etc out.
Personally I prefer a loader with down pressure. Down pressure makes the loader much more versatile for everything from pushing posts into the ground to lifting the tractor’s front end to change a tire.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
