When idling if you can hook a hose to the breather and blow leaves like a shop vac - that's too much blowby...
If idling for 5 minutes and it leaves an oil ring on the ground 10 inches around - that's too much blowby...
Our 1256 would leave an oil spot about the size of a silver dollar in 10 minutes of idling. Started OK, but not great. Still running for the next guy.
Neighbor had a 3688 would leave an oil slick in about 5 minutes, but started just fine so he kept running it.
Hard starting can be caused by a few things:
1. low compression
2. bad injectors
3. low injection pressure (bad pump)
4. incorrect timing of the injector pump
5. poor quality fuel
6. low temps
I can't say I've ever seen our 1086 blow white smoke at start up... Depending on how long and hard you run it before shutting it down, the white smoke could be condensation (water) in the cylinders just burning off. Or it could be a slight coolant leak.
Personally, for determining an overhaul, I would not use blowby. Low oil pressure, high oil consumption, and low compression would be reasons to overhaul. Compression check isn't all that difficult.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
