F-Dean said: (quoted from post at 11:44:59 03/01/09) On my M, which should be similar, I installed the clutch and then adjusted the fingers to all be the same distance from the throw-out bearing -- after I had adjustd the clutch linkage so that the throw-out bearing would be as far back as possible. My logic was to have them all (3 on a M) release at the same time and rate.
If you adjusted them to be as far back as possible you will not have any adjustment for free travel as the clutch wears. As the disc wears thinner the levers will move back farther.
A properly adjusted pressure plate assembly should have the levers about parallel with the friction surface of the cast plate with a new disc installed. Unless the PPA has been disassembled for service you should not have to adjust the lever height. When properly rebuilt they are adjusted to a couple of thousands of an inch, much closer than you can get adjusting then installed in a tractor. Unless something is worn out or broken this adjustment should not change.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
