The valves would operate a loader, but the pump is small and depending on the cylinder diameter, might be slow operating. Also if the one you are looking at has power steering, it "robs" flow from the pump through a "prioity flow divider valve" that would slow a loader even more. Mine has an external loader pump, so the tractor pump operates the PS, 3 point and aux. valves. If the one you are looking at has the optional 3 point, it would mount and run the log splitter, or you could use one of the Aux. valves and forget the pto pump. You are going to be sitting still when using the splitter, so the non-independant pto would not cause a problem. Only problem would be mounting the splitter if it has the Fast Hitch and not 3 point. There are adaptors out there to use it as a 3 point... not sure how easy they are to find or what it would cost. All I use on mine is the loader and a rear blade... it has the factory optional 3 point.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
