Posted by gonecountry on March 03, 2009 at 08:17:34 from (24.224.134.90):
In Reply to: 240 utility questions posted by Janicholson on March 02, 2009 at 19:56:19:
IH fan said: (quoted from post at 02:36:33 03/03/09) The valves would operate a loader, but the pump is small and depending on the cylinder diameter, might be slow operating. Also if the one you are looking at has power steering, it "robs" flow from the pump through a "prioity flow divider valve" that would slow a loader even more. Mine has an external loader pump, so the tractor pump operates the PS, 3 point and aux. valves.
If the one you are looking at has the optional 3 point, it would mount and run the log splitter, or you could use one of the Aux. valves and forget the pto pump. You are going to be sitting still when using the splitter, so the non-independant pto would not cause a problem. Only problem would be mounting the splitter if it has the Fast Hitch and not 3 point. There are adaptors out there to use it as a 3 point... not sure how easy they are to find or what it would cost.
All I use on mine is the loader and a rear blade... it has the factory optional 3 point.
Thanks again for the reply, I'm still confused about the "non independent" PTO though. I'm used to terms like "live" and "ground speed" With the woodsplitter we are sitting still of course lol. and have it set in live with the tractor trans in neutral. and tractor running prob 1800. Willl this 240 do this? Im not too worried if the tractor doesnt have a 3pt which I'm not sure whether or not is does yet. But I'm sure I can fabricate a 3 pt conversion if it hasnt already been done. My friend didnt say what it has I'm sure he assumed it was like most tractors.
Today's Featured Article - Fasteners: The Nuts and Bolts of Nuts and Bolts - by Curtis Von Fange. The nuts and bolts of nuts and bolts is an interesting and essential piece of knowledge that applies to our older tractors. An improperly torqued capscrew on an engine head or a shear bolt that is too hard on the driving shaft of a bushog can create havoc and make an expensive and uncalled for repair. Let’s examine the purpose and design of these fasteners in order to ensure their proper use. Fasteners are probably one of the aspects of mechanics that is given the least amount of thought.
... [Read Article]
Latest Ad:
[More Ads]
