I apologize. I got stuck on Tom's question about the axle nuts and didn't answer the whole question. Sorry, Tom.
You've hit the nail pretty squarely on the head, CNKS. When these tractors were newer, farms were smaller and dealers were plentiful, the parts catalog was not something the average small farmer had buried in the cultch on his bench in the shed. When he needed parts, he went to the dealer. The book was put out for the IH counterman, not for a bunch of guys like us trying to figure things out some 50 years later.
To use Tom's example, when it comes to things like fixtures, threaded bosses and the like on the underside of the transmission, if there was nothing bolted there on the bare tractor covered by the parts book, they would not have felt the need to show them.
To puzzle out where and what they are, you are likely only going to find it in the manual for the implement that might bolt up there. For example, on a different part of the tractor, the torque tube has threaded holes in the implement mounting pads. As far as the tractor parts catalog, all you'll learn is that they take #4 corks. If, however, you had a cultivator and the manual for it, it would show the proper size bolt for those holes to be used in mounting the cultivators. The same would apply to the various bosses on the tranny, diff shaft housing and final drives. As another f'r instance, the bolt sizes for some of the holes in the final drive are found under the listing for the drawbar.
Another example, on the transmission case, the parts catalog simply lists two pipe plugs on the transmission case -- a 1" with a countersunk head, and another in 3/8". Only by looking at the tranny and seeing that these are the only two pipe plugs on it (leaving out the one on the tranny cover which is listed on a different page as part of the cover) and looking at the operator's manual would you discover that the 1" is the tranny drain, and the 3/8" is the level check plug.
So it does take a little looking around, a little noodling, and having the right resources to look through. And then there's the Farmall Board for when you get stumped!
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
