Agreed. The older gas engines from the 1950s run with very low compression ratios. 87 octane will cover their needs without knock or excessive heat easily. As pointed out by Gary current octane ratings would have measured several points higher back in the 1950s and 1960s.
If you are getting engine knock with 87 octane on a engine with less that 8.5:1 compression ratio you have a problem - and it sure **** aint the fuel. Its only when you get up to 9:4 or higher that octane becomes an issue (with pump fuel) - and usually only with mechanical variable ignition timing.
The Super H in 1952 only had a compression ratio of 6.1:1 and the Farmall 450 only had 7:1 compression ratio - well within the operating range of current 87 octane fuel. Running 91 octane fuel in them is a waste of money.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
