Re: Removing Farmall M Axle Housings
Posted by SDE on April 15, 2009 at 06:04:41 from (69.29.232.219):
In Reply to: Removing Farmall M Axle Housings posted by 1 Dollar on April 14, 2009 at 18:25:03:
I replaced the gasket on my 400. I did not think it was real tough. Just take your time. I found the most difficult part to be to get the bull gear off the axle shaft.(after removing PTO) I put a spacer between the two axle shafts and then unthreaded the bolt from one shaft, which then pushed the axle out. I was very fortunate that I did do it that way, because the inner bearing needed to be replaced.
I had thought about doing it as Jim mentioned, and had I done so, I would not have found the bad bearing. Which I thought may have been why it started to leak. Then again it was most likely to have been caused by years of water freezing in the rearend.
Steve
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
