Re: farmall 300 govenor
Posted by Janicholson on April 15, 2009 at 06:24:42 from (199.17.6.128):
In Reply to: farmall 300 govenor posted by case 385 on April 14, 2009 at 20:26:53:
That is not uncommon.
Remove the link from the governor arm (behind gov.) Put the throttle hand lever wide open.
with your hand, pull the governor lever to its full open position (internal stop). Now see where the linkage is related to this position.
The lonkage needs to be short enough to pull this lever to that full open position. If it does with the pin in it it is as good as it can be. If the throttle lever is going back toward idle on its own, it needs to be tightened (if a friction disk type) or have some filing and possible weldup of the teeth/notch/pawl if a ratchet type. JimN
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
