Unless it is an electronic regulator, it should make no difference whether it is used with positive ground or negative ground. Electronic regulators use diodes and transistors and thus are dedicated Positive OR negative ground.
What makes an electro/mechanical regulator positive or negative ground in the material used for the contact points. A regulator dedicated to either positive ground OR negative ground will have contact points made of different materials for longer life. A regulator designed for both positive ground AND negative ground will have both contact points made of the same material which results in a shorter working life.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
