Posted by DJL on April 15, 2009 at 19:27:43 from (65.172.101.94):
Ok, this may be a pretty novice question. What"s the difference between normal hydraulics and live hydraulics? Specifically on a Farmall H. Are the "live" hydraulics where you have to remotes and the pump actually will push a cylinder out and suck it back in, versus the single outlet that will push a cylinder out buy needs mechanical pressure against it to retract? Now that I"ve got that out of the way, here"s the second question. I bought a Farmall H at a farm auction. Serial number checks out as a 1944. It has the original factory hydraulic control lever (like is on our original Farmall M, but no hoses or remotes. I believe the belly pump is working, because I added some hydraulic fluid and when tractor is ideling, if i move the lever it pulls the motor down slightly. So, if I want to run a sickle bar mower behind this tractor I need the remote(s) to raise or lower the bar. On both sides of the H casing close to the belt pully and hydraulic lever is a short pipe with an elbow and capped/Plugged. If i"m sitting on the tractor, I know there"s one on my right hand side, and I believe one on my left hand side. Is one a positive flow line and the other the return line from the implement? If so, do I need to put on 2 remote connectors or just one? I can get a shop to make the hydraulic lines up, but where do I buy the remote connectors? Thanks
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
