Posted by spiffy1 on April 18, 2009 at 08:58:13 from (70.41.137.72):
In Reply to: Hard-starting 15-30 posted by ScottyHOMEy on April 17, 2009 at 19:21:39:
No offense taken, only confused because with modern view [which I'm using] vs. classic view sometimes I think I misinterpret the reply trail.
If you have good compression, you should be able to rule out the rings and valves (which still could be set wrong if good cold and erratic hot, but doesn't sound like the case).
As just noted, you'll have to listen for the impulse (the E4A you can see and hear, but have make sure to manually trip it before cranking), it could be stuck; but if it's running rough it sure could be coil or condensor or points instead or as well as the impulse.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
