Bat terminal on ignition switch should go to alternator side of the amp meter. The wires to coil/resistor and #1 on alternator should connect to IGNition terminal on the switch.
You say the battery is not charging, but the amp meter pegs full to the charging side.
How is your battery connected? With alternator it should be negative ground.
If it is connected positive ground it will "let the smoke out of the alternator" and the system could be going full discharge but the ammeter is connected backwards for the now positive ground battery so it shows full charge.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
