Big job. The TA is in the center section of the tractor, part engine bolts to. You have to double split the tractor, first engine to clutch housing than clutch center housing from rear end. I think this can be done with out removing the cab on the 3688. Then its just a matter of disassembling the center section and replacing the TA unit. As for cost I would figure in the $2000 neighborhood depending on just what parts you find that need replacing. If you have a shop do it add another $1500+ for labor. But before you condem the TA you need to do some checks. The TA is activated by a switch and solinoid in that tractor that can be out of adjustment or faulty. You can use the tractor as is with the TA out and do no harm, you just don't have the extra gears. Good Luck.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
