slydog said: (quoted from post at 15:27:58 04/19/09) Thanks for the advice guys. I will try a little more persuasion to knock the bolts out. I just didn't want to break something not knowing if they were threaded in the yoke or not. Not sure if I can get enough of a swing with a hammer as there is not much room with the lift all pump in there. Does anybody know if I can replace the bearing and seal without taking out the lift all pump?
even if you could get them out with the pump in place, save your self alot of aggrevation and busted knuckles and take it out. it will give you alot more room to work, and it will probably take less time in the end. while you're there, it would be a good time to change the seal on the liftall drive shaft, as it probably leaks too.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
