The spark advance should ground the mag [at the mag: lever way up, maybe 1:00 facing it] when pulled way to the left, it sure doesn't hurt to trade a bit of motion to be on the safe side of turning it off - this wouldn't affect starting, only potentially a bit late at full operating RPM [where you'll have it to the right].
It'd be interesting to post a question on the best time frame and duration for seating the rings, and general break-in: probably get as many answers as # of members activly posting! :lol:
Probably somewhere between 20minutes and 20hours of light loads
(just driving it around I'm of the mindset of a few light trips around the yard [closer to the 20minutes or maybe an hour], at least one long enough to get some temp [at least 130's like a hot water faucet] in the radiator check it over, then a good load for an hour or two)
then give it a load of 1/2 to 3/4 rated
(plow, disk, thresher [if there are enough people and bundles to run an hour straight], or dyno or power-eater)
and get the radiator up to boiling [on water, might want a gauge if you already mixed antifreeze, no idea though of the right number - say 220 constant?] for an hour or better.
I've heard of just covering the radiator and driving it around good and warm, and even claims that quality rings will seat without working it - but logic to me seems that getting it to a solid operating temp and under load before the sleeves glaze is the best chance for the rings to seat. Of course, I wouldn't need to count toes, and maybe not even complete both hands, for the number of engines I've given new rings - so I'm probably over cautious.
For that first or second crank start every time, there are likely some sweet spots - but for starting a few cranks, unless wayyyy too late (like 45degrees back down the stroke), or early enough to kick (or the mag grounding yet in the start position: not the case if you have spark), you shouldn't need that much prescision there.
Same with priming fuel: I do like the cups to see if the carb is cooperating, else just choke for the first couple cranks (on 'loose' engines, I've often used Bob's trick of "mag off"-"choke on" first 4, choke off-mag on the next one, but seldom over a couple pulls with choke (and not even turning off the mag) with good compression) should be enough if the carb [and, of course, everything esle :lol: ] is cooperating.
Good luck! Hope you have more fun than frustration or fatiqued muscles. 8)
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
