Mitch, buddy, calm down a little. Take a breath. Speak in complete sentences. We'll get through this.
Almost 100% chance you do NOT have a bypass block. It would be obvious. There would be a 3/4" thick solid steel block between the hydraulic lines from the engine and the hydraulic unit under the gas tank. There would be hoses coming off this solid steel block going to a hydraulic valve.
Most Cs do not have this block.
The block will cost about $40 from ebay. If you can't find it on Saginaw's site, you just didn't look hard enough. It's there, but more expensive than ebay.
The valve will cost $100 to $200 depending on what you get. If you want a loader that just goes up and down, $100. If you want a hydraulic dump bucket you need to get a remote valve with two controls, $200.
You will also need hoses and fittings to hook it all up. Another $50-$100.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
