Posted by ih560 on April 22, 2009 at 19:31:39 from (67.131.50.233):
In Reply to: Water in the oil! posted by Mac DeBusk on April 22, 2009 at 14:40:02:
Mac DeBusk said: (quoted from post at 14:40:02 04/22/09) I've been working on an old IH Utility 340 gasoline, and I just finished rebuilding the engine where it threw a rod. Part of the job was removing and reinstalling the piston sleeves. Now my number 2 sleeve leaks water. There's no gasket or seal at the bottom of the sleeve. How do I fix the leak?
When you rebuilt the engine did you buy an overhaul kit? If so the new kit should have had new O-rings included. The o-ring can be hard to see in low light but if you shine a flashlight down in there you will see the o- ring located where the bottom of the sleeve slides into the block. The o-ring is located in a groove in the block (like stated) and not on the sleeve. The o-ring is probably 1/4" or so thick and will be mashed flat in the groove.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
