Aw, heck with it, here's the pump, because I thought of 15 different things, now that the coffee has finally hit.
The round intake at the bottom is a FLOATING piece, so that it draws oil from the top of the reserve, rather than drawing the crud off the bottom of the pan. When the tube of the intake (sump) is slid into the pump cover, a cotter pin (which has to be of sufficient heft) goes through the hole in the 'boss' at the left side of the cover, and sits in the 'channel' of the intake's tube, which not only holds it 'captive', but allows it to swing, to sit on top of an oil level that fluctuates based on leaks and/or tilt of the tractor on a hill. If the swing of it is binding, or if the cotter pin fell out and the sump is sitting on the bottom of your pan, that will ALSO mess with your oil pressure.
Also, the four holes on the bottom of the sump could be crusted over with sludge, which could rob you of pressure.
Also, the helical-cut gear at the top of the drive-rod (which engages the camshaft) and the driven-gear at the bottom of that rod are keyed, and if a key sheared, you will also lose oil pressure. Two more things to check. The other gear in the pump body is an idler gear, but make sure it is healthy and spins also.
You can see the relief-piston and spring, and the hole in the boss on the side from which the excess oil goes back into the pan. The next boss up from that (there is another on the other side) is where the bolts go that holds the pump in the block.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
